Fähre Griechenland - Zypern
TRANSPORT: CYPRUS-GREECE CAR FERRY LINK PLANNED
10.06.2010 - ANSAmed
NICOSIA - An ambitious project to restore a car-ferry to service between Cyprus and Greece is in the pipeline, as daily Famagusta Gazette reports. The ferry service linking Limassol port and Lavrio (close to Athens) will use roll-on ferries, capable of carrying cars, lorries and busses according to reports. The authorities are putting together the necessary paper work for parliamentary approval to allow Cyprus to become a ferry hub. The aim of the sea link is to improve trade ties with Greece and offer tourists from both countries an alternative option.
Fähre Lavrio (bei Athen) - Limassol (Zypern) geplant
für PKWs, LKWs und Busse
Quelle: ANSAmed
erren
Re: Fähre Griechenland - Zypern
Beitrag von erren »
Na das wäre ja eine gute Nachricht, hoffentlich tut sich da bald was!!
Jahre später ;-) scheint über eine Fährverbindung Griechenland - Zypern nochmals nachgedacht zu werden:
Cyprus' Government opts for the opportunity to create a ferry line that will link Cyprus and Greece and pushes towards this direction. "We are examining every possibility and evaluating our economic resources," said the Minister of Communications, [...] He also added that "a ferry to Greece would boost Cyprus' tourism sector and build a strong commercial relation between Greece and Cyprus. This relation will increase our opportunity of exporting products to both the Greek and European markets." In addition the creation of a new ferry line that will link the two countries would offer Cypriots and foreign tourists, an alternative way to travel from and to the island. It has been almost a decade since the ferry service that linked Greece and Cyprus has halted. The regular Salamis Lines ferry stopped their scheduled trips in 2002. The ferry line was linking Rhodes, Limassol, and Haifa. The other ferry line - Louise Cruise Lines - that previously sailed weekly from Piraeus and Limassol during summers, halted as well some years ago.
Transport: Nicosia eyes new ferry link Cyprus-Greece
26.11.2013 - ANSAmed
Das ist ja alles ganz schön, aber ohne weitere Verbindungen zum Libanon, nach Israel oder Ägypten nützt die Verbindung zumindest Wüstenschiffenden nix! Dabei gäbe es zumindest im Sommer mit Sicherheit einen ordentlichen Markt in den Libanon: 14 Millionen Auslandslibanesen wollen schließlich jeden Sommer die Heimat sehen und würden sich freuen (jedenfalls diejenigen, die mit dem Auto fahren wollen), die lange Fahrt durch die Türkei und die horrenden Spritpreise zu sparen. Die derzeit zwischen der Türkei und dem Nordlibanon verkehrende Fähre ist zudem wenig zuverlässig und vergleichsweise teuer.
Das zweite Problem ist die fehlende Möglichkeit einer One-Way-Verbindung vom griechischen in den türkischen Teil der Insel oder umgekehrt. Das würde eine Menge Optionen erschließen, die den Tourismus sicher nachhaltiger fördern würden als die jetzt wieder einmal angedachte Torso-Verbindung.
Achim Vogt hat geschrieben:Das zweite Problem ist die fehlende Möglichkeit einer One-Way-Verbindung vom griechischen in den türkischen Teil der Insel oder umgekehrt. Das würde eine Menge Optionen erschließen ...
Hoi Achim
Wie meinst du das mit der fehlenden Möglichkeit einer Einweg-Verbindung zwischen den beiden Zypern?
Kann man nicht im einen Teil einreisen und über den anderen aus? Ich plane drum grad eine solche Tour.
erren
Beitrag von erren »
Du kannst zwar, wenn Du über den griechischen Teil einreist, über den türkischen ausreisen, aber umgekehrt geht's nicht.
Hallo Erren,
ich habe immer mal wieder davon gehört, aber so richtig traue ich dem Braten nicht, dass man über den türkischen Teil ausreisen kann, wenn man über den griechischen eingereist ist. Es heißt immer wieder, dass man in dem Fall nicht mit dem Pass über die Demarkationslinie fahren darf. Aber kann auch sein, dass das heute nicht mehr so ist. In der Tat stehen im HUBB bei Horizonsunlimited diverse Erfahrungsberichte. Also Bäärti, bin sehr gespannt auf Deine Erfahrungen!
VIele Grüße
erren
Beitrag von erren »
Ohne schon gar nicht 8)
