Kenia - Während und nach den Unruhen
Re: Kenia - Während und nach den Unruhen
Schweizer Touristen vergeht Lust auf Kenia
Die Lust der Schweizer auf Kenia-Ferien lässt nach - die Zahl der kostenlosen Annullierungen und Umbuchungen steigt. So wird das Angebot bei Hotelplan «rege genutzt», wie Sprecher Peter Schmidli mitteilt. mehr...
Letzte Aktualisierung: 03.01.2008
Partielle Reisewarnung für die Hauptstadt Nairobi sowie für die westlichen Landesteile. Weiterhin Hohes Sicherheitsrisiko für den Rest des Landes inklusive der Touristengebiete an der Küste.
mehr
Quelle: Außenministerium der Republik Österreich
mehr
Quelle: http://www.irinnews.orgIRIN hat geschrieben: KENYA: Aftermath of poll clashes seen from space
NAIROBI, 4 January 2008 (IRIN) - Two large orange-coloured zones indicate where the worst of Kenya's rural post-election violence has occurred in a new UN map created by focusing civilian satellite cameras onto some of the country's clash-hit areas and revealing the number of fires burning.
The UNOSAT map shows two hotspots of trouble in Kenya's Rift Valley Province - around the town of Eldoret, and a smaller one around the town of Timboroa to the south, along the main road leading to Nairobi.
Other scattered locations in the province are shaded yellow, indicating a lesser but noticeable number of fires.
The satellite data suggest there was much less arson on 2 January than in previous days.
A UNOSAT official, Einar Bjorgo, said higher-resolution imagery would soon be made available on the hardest-hit areas "to pinpoint local damage".
UNOSAT published its map of "active fire locations" online on 4 January. It has used MODIS Aqua and Terra satellites from the election day on 27 December to 2 January.
While the satellite imagery cannot distinguish between naturally-occurring fires or agriculture-related fires and those linked to election violence, UNOSAT states: "It is probable that a majority of detected fires (peaking on 1 January 2008) are directly or indirectly linked to the electoral civil unrest."
UNOSAT also warns that there is a "large degree of uncertainty" and gaps in the data.
However, what emerges is a unique view of where election-related violence has produced fires that can be remotely sensed from space.
In Kenya's Rift Valley Province, media reports and video from media and the Kenya Red Cross have provided vivid evidence of the burning of homesteads, shops and houses in communal violence that erupted after the announcement of fiercely-contested presidential election results.
Bjorgo, head of UNOSAT's rapid mapping unit, told IRIN by phone from Norway that this is the first time the group has produced maps of fire related to civil conflict. Previous maps had been made of forest fires in Europe.
The purpose of the map and others UNOSAT has produced since 2001 is to assist agencies and governments involved in relief operations in logistics and planning, usually after natural disasters such as floods and earthquakes.
While the satellite data is by definition "completely objective" and labelled with disclaimers, Bjorgo said a "spinoff" purpose of the maps is for humanitarian advocacy.
The most prominent example of using satellite imagery for human rights and humanitarian purposes has so far been Amnesty International's Eyes on Darfur project, which mapped villages burnt and at risk of being torched in Darfur using satellite imagery and Google Earth's software tools.
The humanitarian impact of poll-related clashes in Kenya has been hard to assess due to insecurity on the roads and fuel shortages hampering access. A request was made by UN agencies in Kenya to produce the UNOSAT map.
The maps, in PDF format, are available at: http://www.unosat.org/asp/prod_free.asp?id=42
100 000 Kenianer auf der Flucht - Nothilfe läuft an
Das UNO-Flüchtlingskommissariat (UNHCR) hat die Entsendung von Nothilfe für die vor der Gewalt geflohenen Menschen in Kenia angekündigt. Das UNHCR werde Soforthilfe für 100 000 Menschen bereitstellen. mehr...
Verhandlungsstau in Nairobi
Kein Dialog in Kenia: Regierung und Opposition machen sich gegenseitig unannehmbare Vorschläge zur Lösung der Krise. Unterdessen leidet die Wirtschaft, die Börse ist im freien Fall und der Devisenbringer Tourismus droht abzustürzen mehr...
Kenia: Opposition lehnt Teilnahme an Regierung ab
Nairobi. sda/dpa/afp/reuters/baz. In Kenia hat sich Staatschef Mwai Kibaki zur Bildung einer Einheitsregierung mit der Opposition bereiterklärt. Diese solle nicht den Versöhnungsprozess fördern, hiess es in einer Erklärung Kibakis.
Oppositionsführer Raila Odinga lehnte umgehend ab. Es werde auch keine direkten Verhandlungen mit Kibaki geben, der mit «illegalen» Mitteln Präsident geworden sein. Odinga forderte erneut Kibakis Rücktritt. mehr...
Kenias Pseudopräsident sitzt die Krise aus
Vermittlungsversuche gescheitert: Ghanas Präsident Kufuor gibt auf. Jetzt soll Kofi Annan sein Glück versuchen
NAIROBI taz Er war als Hoffnungsträger gekommen, am Donnerstag jettete er ohne greifbares Ergebnis wieder ab nach Hause: Auch John Kufuor, Ghanas Präsident, AU-Vorsitzender und erfahrener Afrika-Diplomat, ist es nicht gelungen, Bewegung in die festgefahrene politische Krise in Kenia zu bringen. mehr...
Kein Ende der Krise - Internationale Vermittler verlassen verbittert Kenia
Die Kluft zwischen Präsident und Oppositionsführer wird tiefer, die Liste der gescheiterten Vermittler länger: In Kenia ist kein Ende der politischen Unruhen abzusehen. Fluchtartig haben tausende Touristen das Land verlassen. Eine Reportage aus dem Krisengebiet. mehr...
hallo zusammen,
die situation in mombasa ist zurzeit ruhig, das leben verlauft normal.
die polizei hat uns heute empfohlen, ab kommenden mittwoch groessere staedte zu meiden, da ab mittwoch landesweit grossdemonstrationen geplant sind.
wie wir erfahren haben, sind die strassen westlich nairobi in richtung uganda zum teil gesperrt, die grenzen in richtung uganda und aethiopien zeitweise nicht geoeffnet.
gruss aus mombasa,
birgitt + siggi
gruss aus mombasa,
birgitt + siggi
KRISE IN KENIA
Wer Sterbende rettet, macht sich strafbar
18.01.2008
Das Urlaubsland als Terrorstaat: Die Polizei schießt scharf, Killerkommandos ziehen durch die Slums. Und die Regierung verkündet über die Zeitungen, wo sie die Ursache für das Chaos sieht: in der "Propaganda" ausländischer Diplomaten und Journalisten ... mehr
18.01.2008
Neue schwere Zusammenstöße in Kenia
18.01.2008
Nairobi (dpa) - Am Freitag ist es in Kenia erneut zu schweren Zusammenstößen zwischen Polizei und Demonstranten gekommen ... Anhänger der Opposition demonstrieren seit Mittwoch landesweit ... mehr
_______________
Kenya protesters to mount boycott
18.01.2008
Kenya's opposition says it will change tactics to protest against the outcome of last month's presidential election, following three days of mass rallies ... mehr bei BBC
_______________
18.01.2008
bin seit einigen tagen in kikambala, ca. 40 km noerdlich mombasa.
hier ist alles ruhig und von den unruhen nichts zu bemerken.
gruss aus kikambala
siggi
gruss aus kikambala
siggi
Unruhen in Kenia
Hoffnung geht in Flammen auf
Der umstrittene Präsident Mwai Kibaki vermasselt Kofi Annans Vermittlungsversuch - und die Gewalt nimmt wieder zu
26.01.2008
NAIROBI taz Die Szene ließ Kenia hoffnungsvoll aufatmen: Der umstrittene Präsident Mwai Kibaki und sein Widersacher Raila Odinga reichen sich die Hände. Das reichte, um das Land zum Jubeln zu bringen. Der als Vermittler angereiste ehemalige UN-Generalsekretär Kofi Annan hatte geschafft, was seit den Wahlen am 27. Dezember niemandem gelungen war ... mehr
26.01.2008
Ortschaft in Kenia zur Hälfte niedergebrannt
Die Unruhen in Kenia gehen weiter, Tausende sind auf der Flucht
Bei erneuten Unruhen in Kenia sind mehrere Menschen getötet und viele verletzt. Eine Ortschaft wurde zur Hälfte niedergebrannt, Tausende wurden obdachlos. Eine Lösung des Konflikts ist nicht in Sicht. mehr...
Brennende Häuser in Naivasha - Mehr als 60 Tote in Provinzhauptstadt Nakuru - Kofi Annan in der Provinz Rift Valley
Stammeskämpfe in Kenia mit Machete, Pfeil und Bogen
Wochenendzusammenfassung
27.01.2008
Naivasha/Kenia (AP) Die blutigen Stammeskämpfe in Kenia haben erneut mehr als 60 Menschen das Leben gekostet. Dabei wird immer deutlicher, dass die anhaltenden Zusammenstöße rivalisierender Stämme kaum noch etwas mit der umstrittenen Präsidentenwahl vom Dezember zu tun haben. Das Zentrum der Kämpfe war am Wochenende Nakuru: In der Hauptstadt der Provinz Rift Valley gingen bis Samstagmorgen Kikuyu und Angehörige anderer Stämme aufeinander los. In zwei Tagen wurden 60 Menschen getötet ... mehr
27.01.2008
Kenia brennt weiter
Quelle: N24
Trotz Annan-Besuch:
Bei neu aufgeflammten ethnischen Unruhen sind in der Provinzhauptstadt des zentralkenianischen Rift Valleys nach Medienberichten in den vergangenen Tagen bis zu 53 Menschen getötet worden. In Nakuru seien seit dem vergangenen Donnerstag zudem mehr als 100 Menschen verletzt worden, berichtete die Zeitung "Daily Nation" am Sonntag. Die Polizei sprach dagegen von 31 Toten....
Mehr
jürgen
Trotz Annan-Besuch:
Mehr
jürgen
